Normal Topic Question about Layout (Read 1181 times)
chris
Oct 30th, 2009 at 7:51pm
Hi Stoyan,
I have some anchor points for each node and each link should be connected to two specified anchor points.
After I create a SpringLayout and call Arrange method to layout my diagram, some properties of the links are changed. For example, the links don't connect to anchor points anymore.
What should I do to keep all the properties of the links unchanged after Arrange method is called?
Thanks.
Re: Question about Layout
Reply #1 - Nov 1st, 2009 at 9:51am
Hi Chris,
You could set layout.Anchoring = Anchoring.Keep. However, SpringLayout doesn't try to place nodes at positions that would allow connected anchor points to end up closer to one another, and you might get some links going over their incident nodes in order to keep their original anchor points.
