Normal Topic ContainerNode not shifting down the other nodes (Read 1636 times)
Hamdy Ghanem
Nov 4th, 2009 at 7:24am
I have a designer
in the designer if the user put a container and close it
then put another shapes
if the user open the container (expand it) it will open over the down controls
is there any facility to let the use shift the shapes down it when it expands
Re:  ContainerNode not shifting down the othe
Reply #1 - Nov 4th, 2009 at 11:01am
You could handle the ContainerUnfolded event and shift the nodes down from the handler. To shift the nodes, first sort them by their Y position using a Comparer similar to the one shown here, but changed for Y:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=124594289...
Then for all nodes that are after the container in the sorted list, add the container's expanded height to their Y position.
