Normal Topic Adjustment handles with custom node (Read 2128 times)
rajesh_patil74
Nov 6th, 2009 at 6:11am
Hi Stoyo
With V1.2 Beta , in tutorial, I modified the OrgChatNode class and following function added to it to show only four adjustment handles.
I want to hide the center adjustment handle, since I am placing command button over there. Selecting the node hides(overlapes) my small button added in center.
With following function, i am showing only 4 adjustment handles and works correctly when i select the node but when i start moving the node all nine adjustment handles are shown and remains visible after moving node is completed.
       protected override void AddHandlesToCanvas()
           Rect _rect = GetBounds();
           Point[] pointArray = new Point[4];
           pointArray[0] = new Point(_rect.Left, _rect.Top);
           pointArray[1] = new Point(_rect.Right, _rect.Top);
           pointArray[2] = new Point(_rect.Right, _rect.Bottom);
           pointArray[3] = new Point(_rect.Left, _rect.Bottom);
           base.AddHandlesToCanvas(pointArray);
I need to show only 4 adjustment handle when moving operation is in progress and after completion.
-Rajesh
rajesh_patil74
Re: Adjustment handles with custom node
Reply #1 - Nov 6th, 2009 at 6:31am
Hi Stoyo
I found the fix for same. By implementing following function it gets resolved.
protected override void UpdateVisuals()
base.UpdateVisuals();
     base.SetRect(_rect);
base.UpdateHandlePositions(pointArray);
Would you fix this issue in next release, so I don't need to implement this function.
-Regards
Rajesh
Reply #2 - Nov 6th, 2009 at 9:12am
What we can do is make the UpdateHandlePositions( - no args - ) method public too. It is called during items modification. Your code will still look very similar to what you posted above though...
