Normal Topic Restrict number of Outbound/Inbound Links (Read 3019 times)
donalmeida
Yay...
Nov 6th, 2009 at 6:51pm
There is a Property on the Shapenode that is:
Node.AllowIncomingLinks; Node.AllowOutgoingLinks;
On top of that, is there a property that I can set that restricts number of out bound or inbound routes. for example on a Start task we need to allow only one (1) outgoing route.
Thanks Don
Don Almeida.
Re: Restrict number of Outbound/Inbound Links
Reply #1 - Nov 6th, 2009 at 7:19pm
There isn't such property. You could handle LinkCreating and LinkModifying to prevent the operation when the target node has the maximum number of incoming or outgoing links.
donalmeida
Yay...
Reply #2 - Nov 6th, 2009 at 7:22pm
Sounds good.  I will do so.
Don Almeida.
Don Almeida.
donalmeida
Yay...
Reply #3 - Nov 10th, 2009 at 6:36pm
I tried to write this code, but it gets executed in a loop the moment I try to create a link from a start task;
private void diagram_LinkCreating(object sender, LinkValidationEventArgs e)
// if Start Task
DiagramLinkCollection links = startNode.GetAllLinks();
                   if (links.Count > 1)
                       HandleErrors("Only one out bound route is allowed per Start task");
                       e.Cancel = true;
                       return;
what is th ebest way to cancel the event.
Don Almeida.
Reply #4 - Nov 10th, 2009 at 8:21pm
Setting e.Cancel displays the stop cursor and prevents the operation at the current mouse position, but lets the user drag the handle to a different position. You could call e.CancelDrag() to cancel the operation immediately.
