Normal Topic Want to know about Active Node rule (Read 1204 times)
Anshul
Senior Member
Nov 11th, 2009 at 9:11am
Hi Stoyan,
I want to know about the Active Node Rule. If I select multiple nodes using mouse drag on diagram, how can I know which node will be the active node?
What is the algorithm to set an item as Active?
Please help.
Anshul
Re: Want to know about Active Node rule
Reply #1 - Nov 11th, 2009 at 11:44am
Hi Anshul,
The Diagram.Items element with lowest index that intersects the selection rectangle becomes the ActiveItem. This is actually the item with lowest ZIndex value from the ones in the selection.
Anshul
Senior Member
Reply #2 - Nov 12th, 2009 at 6:43am
Thanks Stoyan.
