Normal Topic Problem with Hierarchical Layout (Read 1100 times)
Anshul
Senior Member
Nov 18th, 2009 at 3:06pm
Hi Stoyan,
I am having set of nodes in the diagram with links between them.
Consider the node names to be 1,2,3
Links Between:1 -> 2
                      2 -> 3
                      1 -> 3
Now I select Hierarchical layout.
After that links 1->3 hides behind 1->2 and 2->3.
It should not hide, should be managed such that link can be easily seen/identified.
I am sending you the images regarding this on your Support ID.
Following is the code for Getting Hierarchical Layout.
public void ArrangeMapLayout(ArrangeLayout layout)
           try
               switch (layout)
                   case ArrangeLayout.Compact:
                       GridLayout gridLayout = new GridLayout();
                       gridLayout.GridSize = gridLayoutSize;
                       gridLayout.KeepGroupLayout = true;
                       gridLayout.LayoutNode = LayoutNodeHandler;
                       //Included to prevent multiple layout arrangements
                       //specify any positive value other then 0 for RandomSeed
                       gridLayout.RandomSeed = 10;
                       gridLayout.Arrange(diagram);
                       //To reset link's SegmentCount and Style.
                       foreach (DiagramLink link in diagram.Links)
                           link.SegmentCount = 1;
                           link.Style = LinkStyle.Polyline;
                       ArrangeMap();
                       break;
                   case ArrangeLayout.Hierarchical:
                       LayeredLayout layeredLayout = new LayeredLayout();
                       //layeredLayout.LinkType = LayeredLayoutLinkType.Cascading;
                       //layeredLayout.Orientation = MindFusion.Diagramming.Wpf.Layout.Orientation.;
                       layeredLayout.KeepGroupLayout = true;
                       layeredLayout.LayoutNode = LayoutNodeHandler;
                       layeredLayout.Direction = Direction.Straight;
                       layeredLayout.Arrange(diagram);
                       ArrangeMap();
                       break;
           catch (Exception ex)
               Debug.WriteLine("Exception in TopologyViewControl.ArrangeMapLayout : " + ex.Message);
Anshul
Re: Problem with Hierarchical Layout
Reply #1 - Nov 18th, 2009 at 6:21pm
Do not assign these values after the layeredLayout.Arrange call and the links will be easy to see:
