Normal Topic Problem with Hierarchical layout and bending Link (Read 2876 times)
Anshul
Senior Member
Nov 19th, 2009 at 5:48am
Hi Stoyan,
We are using following code for arranging Hierarchical layout.
LayeredLayout layeredLayout = new LayeredLayout();
                       //layeredLayout.LinkType = LayeredLayoutLinkType.Cascading;
                       //layeredLayout.Orientation = MindFusion.Diagramming.Wpf.Layout.Orientation.;
                       layeredLayout.KeepGroupLayout = true;
                       layeredLayout.LayoutNode = LayoutNodeHandler;
                       layeredLayout.Direction = Direction.Straight;
                       layeredLayout.Arrange(diagram);
                       //To reset link's SegmentCount and Style.
                       foreach (DiagramLink link in diagram.Links)
                           link.SegmentCount = 1;
                           link.Style = LinkStyle.Polyline;
There are two scenarios in the arraged hierarchical layout.
1.When we use foreach loop we get overlapped links.
2.When we don't use foreachloop we get bending links.
We don't want both.
Is there anyother way to do this?
Please suggest for this .
Anshul
Re: Problem with Hierarchical layout and bending L
Reply #1 - Nov 19th, 2009 at 8:27am
Try enabling the StraightenLongLinks property of LayeredLayout. You should get at most two bends per link with it.
Anshul
Senior Member
Reply #2 - Nov 19th, 2009 at 1:26pm
Hi Stoyan,
I don't want two bends per link. Is it possible to have straigth link with any band or overlapping ?
Anshul
Reply #3 - Nov 19th, 2009 at 1:38pm
I think only CircularLayout can do that for arbitrary graphs. You might also try using StraightenLongLinks with LayeredLayout and then set the links' SegmentCount to 1. That might still decrease the chance for links to overlap with nodes.
Anshul
Senior Member
Reply #4 - Nov 19th, 2009 at 4:14pm
Hi Stoyan,
Can you please provide some code snippet to perform Hierarichical operation using CircularLayout?
As I don't have any idea of CircularLayout, your initial help will guide me to make further modification.
Anshul
Reply #5 - Nov 20th, 2009 at 2:55pm
CircularLayout does nothing to display hierarchical relations. It just lets you display the graph using only single-segment links without any link-node overlaps. Sorry but you can’t have it all; either use TreeLayout and LayeredLayout to display hierarchies, or CircularLayout to display the connections using only single-segment lines.
Anshul
Senior Member
Reply #6 - Nov 21st, 2009 at 7:26am
Thanks Stoyan, Thanks for the information.
