Normal Topic Validating data in Mindfusion Diagrams (Read 1970 times)
samrat.ghose
Nov 19th, 2009 at 12:02pm
  We are using MindFusion WPF diagram to create forms with controls such as textbox , combobox etc in them. We are setting the minlength and maxlength for the controls say a textbox. Now when the user inputs data how do we vaidate the data the user has entered for minlength , maxlength.
Does mindfusion provide any programmatic APIs for data validation?
Thanx in advance.
Re: Validating data in Mindfusion Diagrams
Reply #1 - Nov 19th, 2009 at 12:31pm
The control does not provide any built-in validation. If you have some WPF bindings attached to the hosted controls, you could add ValidationRules to these bindings and display validation errors using the System.Windows.Controls.Validation class.
samrat.ghose
Reply #2 - Nov 19th, 2009 at 12:37pm
Hi ,
Thanks for the reply. We are saving the mindfusion diagram as xml and then using the following API of midfusion diagram
WpfDiagram.LoadFromString(this.FormXml);
to generate the screen . 'FormXml' contains all the controls and values along with atributes such as 'minmaxlength' .
Is there a way to validate the data entered in these controls against the stored validation attributes.
Reply #3 - Nov 19th, 2009 at 12:55pm
After loading, you could loop over all nodes and add some bindings to their hosted controls:
TextBox textBox = (node as DiagramNodeAdapter).UIElement as TextBox;
if (textBox != null)
	Binding binding = new Binding("Value");
	// assuming Tag objects have a Value property
	binding.Source = node.Tag;
	// todo: add validation rules here
	textBox.SetBinding(TextBox.TextProperty, binding);
This MSDN topic shows how to create a min/max rule, which you can add to the ValidationRules collection of the "binding" object.
http://msdn.microsoft.com/en-us/library/system.windows.data.binding.validationru...
