Normal Topic Unable to resize a DiagramNode (Read 2460 times)
GDICommander
Nov 19th, 2009 at 3:55pm
Hi, everyone!
I'm trying to resize a DiagramNode in an event handler by using the Resize method. Unfortunately, it doesn't work.
I'm using a class, StateDiagramItem, that derives from ShapeNode, that derives from DiagramNode.
It's strange, because in the constructor of StateDiagramItem, a call to Resize works!
Can somebody help me?
Re: Unable to resize a DiagramNode
Reply #1 - Nov 19th, 2009 at 4:22pm
What event are you handling exactly? Calling Resize on an item that's currently being modified won't work. Instead you will have to override the UpdateModify method. If calling Resize on a different node but still during some item's modification, you must call the RecreateCacheImage method.
GDICommander
Reply #2 - Nov 19th, 2009 at 4:34pm
I looked at my code and the Resize operation that doesn't work is done on an event handler that is hooked on the OnNodeTextEdited event. So, according to your last post, I can't call Resize here because the node is being modified.
GDICommander
Reply #3 - Nov 19th, 2009 at 4:51pm
Unfortunately, I don't know where UpdateModify and RecreateCacheImage methods are. Can you tell me where they are?
Reply #4 - Nov 19th, 2009 at 5:43pm
DiagramItem.UpdateModify and DiagramView.RecreateCacheImage.
