Normal Topic Problem with custom anchor points (Read 1360 times)
Bruno
There's always one more
bug.
Nov 23rd, 2009 at 2:57pm
My application requires that the anchor points are displayed outside the node, with their name inside the node. I used to do that with Flowchart.NET Pro 5.0.2 with custom draw. I tried to reproduce this behavior with WpfDiagram, but I'm experimenting some problems.
First, the documentation and examples regarding the DrawAnchorPointEventArgs look incorrect (wrong members). This does not help !
Then, there seems to be an offset between the expected and the actual coordinates of the anchor point. As a test, I tried drawing rectangles at fixed coordinates (eg. 100,100) in the DrawAnchorPoint event handler using the DrawingContext, and get rectangles at 212,212 (roughly). Strange, isn't it ?
Can you please help me ?
Thanks in advance.
Bruno
Re: Problem with custom anchor points
Reply #1 - Nov 23rd, 2009 at 3:44pm
A difference from the WinForms version is that the draw handlers should use coordinates local for the node. E.g. if the node is located at 112 and you draw locally at 100, the end result will appear at 212.
Bruno
bug.
Reply #2 - Nov 23rd, 2009 at 4:22pm
Yes, that definitely helped.
Thanks a lot !
Bruno
