Normal Topic Problem with Dragging node to the Left of Diagram (Read 1283 times)
Anshul
Senior Member
Nov 24th, 2009 at 6:31am
Hi Stoyan,
I am having set of Nodes in the diagram.
When I drag the nodes to the rightmost , the diagram expands along with the drag and also the scrollviewer expand respectively.
On the other hand when I drag the node to the leftmost, the diagram doesn't expand and node returns back to the original position and scrollviewer also doesn't expand.
Please suggest for this.
Anshul
Re: Problem with Dragging node to the Left of Diag
Reply #1 - Nov 24th, 2009 at 7:54am
Hi Anshul,
Set <Diagram AutoResize="AllDirections" ...>
Anshul
Senior Member
Reply #2 - Nov 24th, 2009 at 8:28am
Thanks Stoyan  Cheesy
