Normal Topic 5.3.3 Beta - Link change bug (Read 2262 times)
TimNZ
Nov 24th, 2009 at 11:14pm
First screenshot is diagram laid out using Layered Graph.
2nd screenshot shows non straight links changing by themselves that are connected to the TreeViewNode that all I did is change the scroll position (either by moving scroll bar or clicking up/down buttons).
Link to diagram.xml file - by the way, this diagram takes 13 seconds to serialise to XML on a Xeon 2.66GHZ server that isn't doing much. It is a 1mb file.
http://www.enetworks.co.nz/temp/diagram.xml
Cheers,
Tim
Re: 5.3.3 Beta - Link change bug
Reply #1 - Nov 25th, 2009 at 12:50pm
This seems to happen because of the Dynamic property of links. Disable it, and links will remain in place when scrolling nodes.
