Normal Topic Need selected area at the center of the diagram (Read 4528 times)
Anshul
Senior Member
Nov 25th, 2009 at 4:51pm
Hi Stoyan,
We have some nodes in our diagram.
We want to magnify some of the nodes, for that we are selecting that nodes using mouse drag. When we drag the mouse a ned rect is created and we want to magnify that rect portion only. For this purpose we are using following code.
Point oldCursorPosition = diagram.ClientToDoc(Mouse.GetPosition(diagram.Parent as ScrollViewer));
		    double newScrollX = diagram.ScrollX;
		    double newScrollY = diagram.ScrollY;
		    diagram.ZoomFactor = 200;
		    Rect newBounds = diagram.ClientToDoc(new Rect(0, 0, scrollViewer.ActualWidth, scrollViewer.ActualHeight));
		    Point newCursorPosition = new Point(newBounds.X + newBounds.Width / 2, newBounds.Y + newBounds.Height / 2);
		    double diffx = (oldCursorPosition.X - newCursorPosition.X);
		    double diffy = (oldCursorPosition.Y - newCursorPosition.Y);
		    newScrollX += diffx;
		    newScrollY += diffy;
		    newBounds.X = newScrollX;
		    newBounds.Y = newScrollY;
		    newBounds.Union(diagram.GetContentBounds(false, false));
		    newBounds.Inflate(200, 200);
		    diagram.Bounds = newBounds;
		    diagram.ScrollTo(new Point(newScrollX, newScrollY));
It is working very fine. We want after magnification, this rect will come at the center of the diagram so that when we perform zooming, we always get this rect as center, how can we do this?
Anshul
Re: Need selected area at the center of the diagra
Reply #1 - Nov 27th, 2009 at 3:33pm
Can't you just call the diagram.ZoomToRect() method?
priyanka
Reply #2 - Nov 30th, 2009 at 11:04am
diagram.ZoomToRect() will zoom the content of the rect to fit the diagram completely.
But the requirment is the zooming should get performed taking that selected rectangle as center to zoom,
ie. when we zoom in/out the zooming should get performed with respect to the specified rectangle only and not from the center of diagram.
Reply #3 - Nov 30th, 2009 at 12:48pm
Isn't that the same as zooming around a given point, where the point is the center of the rectangle in this case? Some time ago I sent you the code for a mouse-wheel handler that does this.
MikeHeal
Re: Need selected area at the center of the diagram
Reply #4 - May 13th, 2021 at 6:45pm
I am having the same issue.
Whats the solution for it! Can someone please share the sample code here..
Thank you.
Online
Reply #5 - May 14th, 2021 at 6:02am
If you mean you need to change zoom with viewport's center staying at same position, you should be able to use these methods -
public void SetZoomFactor (
    double zoomFactor,
    Point pivotPoint
public void ZoomToRect (
    Rect rect,
    bool centered
