Normal Topic AttachTo and NullReferenceException (Read 3878 times)
oOAnriOo
Nov 26th, 2009 at 2:07pm
Im trying to attach 2 nodes derived from DrawingNode.
Both drawings exists on the diagram but for some reason I get a nullreference exception when calling the attachto function.
The code is too complex to show here, but is there something, other than creating 2 nodes on a diagram, I need to do before I can attach node 1 to node 2?
Re: AttachTo and NullReferenceException
Reply #1 - Nov 26th, 2009 at 4:19pm
Could you post here the exception stack trace? What class does DrawingNode derive from?
oOAnriOo
Reply #2 - Dec 2nd, 2009 at 7:30am
Oh..  Sorry..
i meant DiagramNode, not DrawingNode.  My object is derived from MindFusion.Diagramming.DiagramNode and just a few parameters added.
Here is my stack trace :
Quote:
System.NullReferenceException was unhandled
  Message="Objektreferencen er ikke indstillet til en forekomst af et objekt."
  Source="MindFusion.Diagramming"
  StackTrace:
      ved MindFusion.Diagramming.DiagramNode.xf5780211a26cd3d0(DiagramItem xccb63ca5f63dc470)
      ved MindFusion.Diagramming.DiagramNode.AttachTo(DiagramNode node, AttachToNode attType)
      ved NeetsProjectEditor.Controls.Overview.ProjectOverview.CreateDrawing(ProjectDiagra
m diagram) i C:\Users\hlc\Documents\Visual Studio 2008\Projects\Project overview\Project overview\Project overview.cs:linje 152
      ved NeetsProjectEditor.Controls.Overview.ProjectOverview.ChangeViewMode() i C:\Users\hlc\Documents\Visual Studio 2008\Projects\Project overview\Project overview\Project overview.cs:linje 183
      ved NeetsProjectEditor.Controls.Overview.ProjectOverview.set_ViewMode(ViewModes value) i C:\Users\hlc\Documents\Visual Studio 2008\Projects\Project overview\Project overview\Project overview.cs:linje 54
      ved Project_overview.Form1.uiTrackBar1_ValueChanged(Object sender, EventArgs e) i C:\Users\hlc\Documents\Visual Studio 2008\Projects\Project overview\Project overview\Form1.cs:linje 58
      ved Janus.Windows.EditControls.UITrackBar.OnValueChanged(EventArgs e)
      ved Janus.Windows.EditControls.UITrackBar.set_Value(Int32 value)
      ved Janus.Windows.EditControls.UITrackBar.a(Int32 , Int32 )
      ved Janus.Windows.EditControls.UITrackBar.OnMouseMove(MouseEventArgs e)
      ved System.Windows.Forms.Control.WmMouseMove(Message& m)
      ved System.Windows.Forms.Control.WndProc(Message& m)
      ved System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
      ved System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
      ved System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
      ved System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
      ved System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNat
iveMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
      ved System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
      ved System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
      ved System.Windows.Forms.Application.Run(Form mainForm)
      ved Project_overview.Program.Main() i C:\Users\hlc\Documents\Visual Studio 2008\Projects\Project overview\Project overview\Program.cs:linje 18
      ved System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
      ved System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
      ved Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
      ved System.Threading.ThreadHelper.ThreadStart_Context(Object state)
      ved System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
      ved System.Threading.ThreadHelper.ThreadStart()
  InnerException:
Reply #3 - Dec 2nd, 2009 at 9:16am
The attach code tries to access the target's parent diagram at one point, so you might get this error if the target node hasn't been added to the diagram yet. Try calling AttachTo after diagram.Nodes.Add().
oOAnriOo
Reply #4 - Dec 2nd, 2009 at 9:43am
Damn..  How could I overlook such a simple mistake..
The case was just as you suggested.
Thanks a lot.
Reply #5 - Dec 2nd, 2009 at 10:22am
It's more of our mistake, but it's easier to fix it on your side Wink
