Normal Topic Creating ShapeNode programmatically (Read 3306 times)
Hunter
Dec 1st, 2009 at 12:57pm
Hello. I downloaded the trial version of the MindFusion.Diagramming for WPF. I tried to create the node such as:
    int nInpNum = int.Parse(dlg.textBoxInps.Text);
    int nOutNum = int.Parse(dlg.textBoxOuts.Text);
    ShapeNode node = m_Diagram.Factory.CreateShapeNode(40, 40, 5, 80, Shapes.Rectangle);
    AnchorPointCollection anchorPnts = new AnchorPointCollection();
    double nOffset = nInpNum > 0 ? 100 / (nInpNum + 1) : 50;
    for (int i = 0; i < nInpNum; ++i)
  AnchorPoint point = new AnchorPoint(0,
nOffset * (i + 1), true, false, MarkStyle.Rectangle);
  anchorPnts.Add(point);
    nOffset = nOutNum > 0 ? 100 / (nOutNum + 1) : 50;
    for (int i = 0; i < nOutNum; ++i)
  AnchorPoint point = new AnchorPoint(100,
nOffset * (i + 1), false, true, MarkStyle.Rectangle);
    node.AnchorPattern = new AnchorPattern(anchorPnts);
    node.EnabledHandles = AdjustmentHandles.ResizeTopCenter |
  AdjustmentHandles.ResizeBottomCenter | AdjustmentHandles.Move;
    node.HandlesStyle = HandlesStyle.EasyMove;
    node.Brush = Brushes.Black;
Anchor points creates successful. Node creates also successful but it isn't resize or move. What's wrong?
Re: Creating ShapeNode programmatically
Reply #1 - Dec 1st, 2009 at 1:30pm
Do you see the stop cursor shown while moving or resizing, or you can't start any modification at all? It seems the modification code doesn't allow nodes to be set smaller than 2 mm in any dimension, even if you are resizing in the other dimension, so if the node starts 5 points wide, this might cause the problem. You might create a bit wider node to allow modifications, or otherwise we'd have to add some property that defines the minimum size allowed for nodes to let you make it <= 5 points.
Hunter
Reply #2 - Dec 1st, 2009 at 1:45pm
Stoyo wrote on Dec 1st, 2009 at 1:30pm:
Thank you very much! I created the wide 8 points and all works as I need. If the wide less or equal to 7 then it works with problems. All modifications starts successful but not finished. Stop cursor is really present in this case. I think that 8 points is possible wide for my task. But it will be good if it is possible to create the wide less than 8 points for visualize the bus on the diagram.
Reply #3 - Dec 1st, 2009 at 3:33pm
Ok, we'll try to make this minimum size a property later this week.
Reply #4 - Dec 16th, 2009 at 3:52pm
This version adds MinimumNodeSize property to Diagram:
https://mindfusion.eu/_beta/wpfdiag23.zip
Set it to "4,4" or smaller value, and you will be able to modify the 5-point wide node.
Hunter
Reply #5 - Dec 17th, 2009 at 1:04pm
