Normal Topic 5.3.3 - Deserialization from XML (Read 6632 times)
TimNZ
Dec 2nd, 2009 at 12:59am
When loading a diagram from XML, the EnableStyledText property for TreeViewNode is not applied (I mentioned it back in September).
TimNZ
Re: 5.3.3 - Deserialization from XML
Reply #1 - Dec 11th, 2009 at 3:52am
Someone needs to add Captcha to their Registration process  Tongue
Reply #2 - Dec 14th, 2009 at 8:40am
Yay, but we think they use a human to create a spam account and feed it to the bot system, so a captcha won't help.
Anyway, regarding the XML issue, it turned out there's some misdesign on our side. The base LoadFromXml code deserializes EnableStyledText only if the class version it has been registered with is at least 2. So that will work correctly if you call RegisterClass with the version argument set to 2:
Diagram.RegisterItemClass(typeof(TableNode), "custom:TableNode", 2);
We've also made the active DiagramView repaint immediately while scrolling TreeView nodes under Win7. Let me know if you need it urgently and we'll upload a version for you. Otherwise that will be available with a small release in January.
TimNZ
Reply #3 - Dec 14th, 2009 at 9:19am
Great.  I can wait till January (guess I better renew my subscription...)
What's coming in 2010?
Reply #4 - Dec 14th, 2009 at 2:18pm
A couple of new layout classes: The first will arrange diagrams with nested containers. The second one will be a combination of radial tree and circular layouts. And then we also have about 150 features in the flowchart.net wish-list to choose from - they were about 250 last year, so it's getting close to perfection 8)
TimNZ
Reply #5 - Dec 14th, 2009 at 8:11pm
Yes, so close to perfect Wink
Perhaps you could post a list of all the suggestions/requests/proposed changes somewhere for us to review and vote on. I guess WPF/Silverlight will be getting a lot of attention in 2010, and will be something I do my future GUI with.
Reply #6 - Dec 18th, 2009 at 2:25pm
Sounds good, we'll check if there is some poll mod for the YaBB forum we are using. Otherwise I suppose people can just post their favorite requests, but this could make the list longer and longer 8)
