Normal Topic use of BAckgroundImageUrl (Read 3320 times)
ebibnet
Dec 6th, 2009 at 11:22pm
Hi guys,
We are trying to use the BackgroundImageUrl property.
  <ndiag:DiagramView  runat="server" ID="diagramView"
           ShowScrollbars="true"
           BorderColor="Black"
           ClientSideMode ="ImageMap"
            <Diagram   BackgroundImageUrl="http:// .... "           />
       </ndiag:DiagramView>
Somehow we don't manage to make it work.
Is there something we missed (does it only work for applet or ...? )
Is there an example somewhere or ...?
Thannnkkkks!!!!
Re: use of BAckgroundImageUrl
Reply #1 - Dec 7th, 2009 at 8:08am
Hi there,
Indeed it's used only in JavaApplet mode. We added it for a client some time ago to make the applet show the diagram faster, while the image is downloaded in a background thread. In ImageMap mode you can load the image from the page_load handler:
diagramView.Diagram.BackgroundImage = Image.FromFile(imagePath);
ebibnet
Reply #2 - Dec 7th, 2009 at 1:32pm
oh that is bad news...  Cry
our homepage contains a imagemap with a background , we load it from an xml file...
only the issue is that when we use an image as background with a size of approx 200k size...
the homepage grows quickly , we found out that the size of the page becomes > 1.2 MB...
The viewstate grows uncontrolled...
so we were hoping for another solution like BackgroundImageUrl...
Thanks !
R.
Reply #3 - Dec 7th, 2009 at 1:56pm
You might add a handler to diagramView.Diagram.DrawBackground and draw the background from the handler by calling e.Graphics.DrawImage instead of setting the property. This will avoid the big viewstate size.
