Normal Topic Strange behaviour with AttachToLink (Read 3085 times)
DKHMM
Dec 7th, 2009 at 12:01pm
Hi Mindfusion.
I'm trying to add a shape to links, and in most cases it works with success, but some of them are unfortunately misplaced.
Please see the example below:
[code]
ShapeNode newShape1 = diagram.Factory.CreateShapeNode(40, 40, 20, 20, Shapes.Rectangle);
newShape1.Expandable = true;
for (int a=0; a<10; a++)
ShapeNode newShape = diagram.Factory.CreateShapeNode(0, 0, 20, 20, Shapes.Rectangle);
DiagramLink link = diagram.Factory.CreateDiagramLink(newShape1, newShape);
ShapeNode label = diagram.Factory.CreateShapeNode(0, 0, 10, 10, Shapes.Star);
label.AttachTo(link, AttachToLink.LongestHSegment, 1);
link.SubordinateGroup.Expandable = true;
TreeLayout layout = new TreeLayout { Type = TreeLayoutType.Centered, Direction = TreeLayoutDirections.TopToBottom, LevelDistance = 100 };
layout.Arrange(diagram);
[/code]
[img]http://i736.photobucket.com/albums/xx8/DKHMM/mindfusionError1.jpg[/img]
If I try to change the link with the mouse pointer, it is working, but as soon as I rearrange the layout, some of the shapes are misplaced.
Looking forward to see your reply.
Best regards
Henrik
Re: Strange behaviour with AttachToLink
Reply #1 - Dec 7th, 2009 at 12:48pm
Set label.IgnoreLayout = true and it will work as expected. Otherwise each label is considered a graph on its own, and the code that places multiple graphs will move these one-node graphs to the right.
Just FYI, the next WpfDiagram release will use Shape objects as arrowhead shapes, so there you will be able to set link.IntermediateShape = Shape.Star instead of using attached nodes. This will help if you are using the stars only as decorations.
DKHMM
Reply #2 - Dec 7th, 2009 at 1:03pm
Hi Stoyan
Thanks for your quick reply
It now works as expected.
Henrik
