Normal Topic WPF Diagram 2.2.1.21626 HitTest Exception (Read 5186 times)
Paul Eden
Dec 14th, 2009 at 6:07pm
We just found the following - it occurred when drag-highliting over a node that contained a 3D control.  Is the exception information listed enough to work with or would you also require sample code for reproduction purposes?
Many Thanks
Paul Eden
System.NotSupportedException was unhandled
  Message="'GeometryHitTestParameters' HitTestParameters are not supported on 'Viewport3DVisual'."
  Source="PresentationCore"
  StackTrace:
[snip]
      System.Windows.Media.Visual.HitTestGeometry(HitTestFilterCallback filterCallback, HitTestResultCallback resultCallback, GeometryHitTestParameters geometryParams)
      at System.Windows.Media.Visual.HitTest(HitTestFilterCallback filterCallback, HitTestResultCallback resultCallback, HitTestParameters hitTestParameters)
      at System.Windows.Media.VisualTreeHelper.HitTest(Visual reference, HitTestFilterCallback filterCallback, HitTestResultCallback resultCallback, HitTestParameters hitTestParameters)
      at MindFusion.Utilities.HitTest(Visual v, Geometry g)
      at MindFusion.Diagramming.Wpf.DiagramNode.xa170bf38e993d468(Rect x26545669838eb36e)
      at MindFusion.Diagramming.Wpf.Diagram.x98d300fb770bf5ec(Rect x26545669838eb36e, Boolean x201ab38fe5644146)
      at MindFusion.Diagramming.Wpf.Selection.AllowCreate(Point current, InteractionState ist)
      at MindFusion.Diagramming.Wpf.InteractionState.ValidateAndSetCursor(Point point, Diagram diagram)
      at MindFusion.Diagramming.Wpf.Behaviors.BehaviorBase.OnMouseMove(Point mousePosition)
      at MindFusion.Diagramming.Wpf.Diagram.OnPreviewMouseMove(MouseEventArgs e)
      at System.Windows.UIElement.OnPreviewMouseMoveThunk(Object sender, MouseEventArgs e)
Re: WPF Diagram 2.2.1.21626 HitTest Exception
Reply #1 - Dec 15th, 2009 at 4:48pm
Hi Paul,
Please check if this version fixes it, and send us some sample code if it doesn’t:
https://mindfusion.eu/_beta/wpfdiag23.zip
Paul Eden
Reply #2 - Dec 15th, 2009 at 5:00pm
Hi Stoyan
Will do so as soon as I can - many thanks for the fast reply, as usual.
Paul
Paul Eden
Reply #3 - Dec 24th, 2009 at 12:56pm
Hi Stoyan
Initial testing shows that there is no longer an exception thrown, but compared to "drag-selecting" over empty or non-3D areas, "drag-seletcing" over 3D is very slugish.  This may just be due to the nature of betas though.
Hope this helps
Paul.
