Normal Topic How to draw straight DiagramLinks aligned to grid (Read 1886 times)
solisgsandc
Dec 18th, 2009 at 10:58pm
I would like to know how to draw straight diagram links and align to grid when drawing starts. This could be vertical or horizontal links.
Re: How to draw straight DiagramLinks aligned to g
Reply #1 - Dec 19th, 2009 at 8:54am
There is no built-in support for such links if what you need is the links to stay horizontal or vertical while being drawn. In such case you will have to create a custom link class or a custom behavior class that aligns the link end points. You can see an example below. Otherwise you could handle the LinkCreated and LinkModified events and update the end points when the operation is competed.
class MyBehavior : LinkShapesBehavior
	public MyBehavior(Diagram diagram) : base(diagram) {}
	protected override void OnMouseMove(Point mousePosition)
		base.OnMouseMove(mousePosition);
		var ist = Diagram.Interaction;
		if (ist != null && ist.Action == Action.Create && ist.CurrentItem is DiagramLink)
			var link = ist.CurrentItem as DiagramLink;
			Point sp = link.ControlPoints[0];;
			double dx = Math.Abs(sp.X - mousePosition.X);
			double dy = Math.Abs(sp.Y - mousePosition.Y);
			if (dx > dy)
				mousePosition.Y = sp.Y;
			else
				mousePosition.X = sp.X;
			ist.Update(mousePosition, Diagram);
	protected override void OnMouseUp(Point mousePosition, MouseButton mouseButton)
		DiagramLink link = null;
		Point sp = new Point();
		base.OnMouseUp(mousePosition, mouseButton);
		if (link != null)
			if (dx > dy)
			else
			link.ControlPoints[0] = sp;
			link.ControlPoints[link.ControlPoints.Count - 1] = mousePosition;
			link.UpdateFromPoints();
diagram.CustomBehavior = new MyBehavior(diagram);
