Normal Topic Newbie question on attaching attributes to shape (Read 1292 times)
arisco97
Dec 20th, 2009 at 6:25pm
I did not see any demos so have a question on whether offerings support associating attributes to a shape (For e.g. in Visio: Shape -> Properties).
And within that what capabilities are offered?
Re: Newbie question on attaching attributes to sha
Reply #1 - Dec 21st, 2009 at 10:03am
If you need a predefined set of additional properties, you could add them to your custom ShapeNode -derived class and implement serialization like this:
protected override void SaveToXml(System.Xml.Linq.XElement xmlElement, XmlPersistContext context)
	base.SaveToXml(xmlElement, context);
	context.WriteString(Title, "Title", xmlElement);
	context.WriteString(FullName, "FullName", xmlElement);
protected override void LoadFromXml(System.Xml.Linq.XElement xmlElement, XmlPersistContext context)
	base.LoadFromXml(xmlElement, context);
	Title = context.ReadString("Title", xmlElement);
	FullName = context.ReadString("FullName", xmlElement);
You should also call the RegisterItemClass method to define the xml element name for your nodes.
If you need to let users set arbitrary properties as in Visio, you could implement that by storing them in Dictionary<string,Object> or Dictionary<string,string>, either by adding the dictionary as a property of a custom class or by storing it as a value of the node.Tag property.
