Normal Topic Print problem with zoom implementation (Read 2416 times)
binoo
Dec 20th, 2009 at 11:18pm
First of all sorry for my english... Undecided
When I apply a zoom on my diagram, the print preview is out.
An exemple, on your project FlowCharter, I add MouseWheel event to implement the zoom :
private void diagram_MouseWheel(object sender, MouseWheelEventArgs e){
  Diagram diag = sender as Diagram;
  diag.ZoomFactor += (e.Delta / 20);
When you run the application, if you add nodes that make a preview with 2 pages, then if you zoom down, the preview will stay with two pages even if all the nodes are on the first page.
The problem is similar when you increase the zoom : Only two pages and the digram is not complete.
I work with the 2.2.1 version.
Have you got a solution for my problem ?
Re: Print problem with zoom implementation
Reply #1 - Dec 23rd, 2009 at 9:07am
Try this version -
https://mindfusion.eu/_beta/wpfdiag23_print.zip
Now the print output should not depend on the diagram's zoom factor. If you still need to scale the printed diagram, you can do so by setting the diagram.PrintOptions.Scale. The number of pages should now correctly match the scale.
binoo
Reply #2 - Dec 24th, 2009 at 9:30am
Thank you ! The number of pages is correct.
I appreciate your reactivity ! Smiley
Now, what I have to do is to wait the future "no beta" version.
Thanks.
ps: Maybe you know when you release the future version ?
Reply #3 - Dec 24th, 2009 at 10:26am
Hi
We plan to release it the first week of January.
binoo
Reply #4 - Dec 24th, 2009 at 10:28am
Great !
Thank you very much.
