Normal Topic The tree's Node hide (Read 4261 times)
1900wn
Dec 22nd, 2009 at 5:30am
Hi, about flowchar's example,is DirTree,I look at it,but i think,when the program is running, i think the node is hide,only need top.i try the collapse()function,but have problem.how i do it ? i'm crazy,thank you.
example:
Re: The tree's Node hide
Reply #1 - Dec 22nd, 2009 at 6:53am
Do you need to initially show only the root node and let users expand it to see its children?
1900wn
Reply #2 - Dec 22nd, 2009 at 8:36am
yes,very right,show only the root node and let users expand it to see,if he want expand,what i can do?
i read example code ,like this function?
layoutTree(tldTopToBottom)
i am not sure,  do you have answers?
Thank you ,Stoyo.
Reply #3 - Dec 22nd, 2009 at 11:59am
Doesn't it work if you call root.Collapse after building the tree in the DirTree Form_Load handler?
'read some folders
BuildTree
root.Collapse
1900wn
Reply #4 - Dec 23rd, 2009 at 12:48am
thank you ,i will try , do your way,i see it
1900wn
Reply #5 - Dec 23rd, 2009 at 1:16am
Thank you very much for your help,Stoyo,It success!
thank you !
