Normal Topic Group shapes by criteria (Read 1303 times)
Alex.kg
Dec 22nd, 2009 at 12:34pm
Hi Stoyan,
Could you help to resolve question with layouts:
The idea is visually group shapes in different areas of diagram based on criteria assigned to each shape. Similarly to SpringLayout with enabled clusters.
I've tried the following approach:
- Collect shapes into list of DiagramItemCollection based on criteria
For each DiagramItemCollection did the following:
a. Define area(set SpringLayout.LayoutArea) where group of shapes(DiagramItemCollection) should be located
b. Invoke SpringLayout.Arrange (Diagram, DiagramItemCollection)
But finally I've got shapes arranged into a horizontal line.
Ideally, I'm looking for an approach to group shapes like in the picture:
Alex
Re: Group shapes by criteria
Reply #1 - Dec 22nd, 2009 at 12:59pm
Hi Alex,
If there aren't any links between the group nodes, SpringLayout considers them separate graphs and applies MultipleGraphsPlacement, whose value is Horizontal by default. Try setting SplitGraph to false; then the layout method should treat the nodes as a single graph. You might also try SplitGraph = true with MultipleGraphsPlacement = MinimalArea.
