Normal Topic Link movement between nodes (Read 1236 times)
MUDO
Dec 24th, 2009 at 10:05pm
How can I capture change of origin/destination of link when it is changed between 2 nodes? For ex. I have 3 tables, between #1 and #2 is link. I manually change destination of link to table #3. How to capture this? i need to change data in dataset after this "operation"!
Theres event OriginAnchorChanged and DestinationAnchorChanged but they are fired everytime when origin/destination is changed (while moving node with linked link too Sad ) and I cant retrieve necessary data from AnchorPointEventArgs object.
I thik I can combine LinkStartModifying event (where I set any object (tag of link?) with original origin/destiantion of link) and LinkModified event where I perform control and needed operation.
Is there way how to do it "naturally"? Maybe Im blind coz I havent found it on forum, but Im first who needs this behaviour???
...MUDO...
Re: Link movement between nodes
Reply #1 - Dec 26th, 2009 at 7:24am
If args.AdjustmentHandle == 0 in LinkModified, query the database to see if the stored origin corresponds to link.Origin; update it if it doesn't. You could do the same for link.Destination if args.AdjustmentHandle == link.ControlPoints.Count - 1.
