Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) Dragging links (Read 22165 times)
Hunter
Re: Dragging links
Reply #30 - Jan 6th, 2010 at 2:47pm
Thanks!
Hunter
Re: Dragging links
Reply #31 - Jan 11th, 2010 at 8:29am
I found very distressing effect of working Diagram.GetLinkAt. It doesn't find the necassary link. But instead it finds the another link. I send you the screenshot of the diagram. Look at the right decision node. When the mouse is over the top link the GetLinkAt returns the bottom link. How can I avoid this effect?
Re: Dragging links
Reply #32 - Jan 11th, 2010 at 9:30am
Try setting LinkHitDistance to some small value, e.g. two points. GetLinkAt returns the first link it finds within that distance.
Hunter
Re: Dragging links
Reply #33 - Jan 11th, 2010 at 9:33am
There is no effect. It was:
var link = Diagram.GetLinkAt(point, 3, true, ref segment);
I try to set:
var link = Diagram.GetLinkAt(point, 1, true, ref segment);
Hunter
Re: Dragging links
Reply #34 - Jan 11th, 2010 at 9:40am
I note that it takes place in case when the ended contol points of the links have overlapped coordinates. In my example the start point of the first link has coordinates {262,5;247,5}and the last point {612,5;382,5}.
The last control point of the second link has coordinates {612,5;322,5}
I see that the X-coordinates is equal and the Y-coordinate is between 247,5 and 382,5. In case like this tha same behavior takes place
Re: Dragging links
Reply #35 - Jan 11th, 2010 at 9:55am
Does it select the wrong link if you click to select it? could you save the diagram to xml and email it so support@mindfusion.eu?
Hunter
Re: Dragging links
Reply #36 - Jan 11th, 2010 at 10:04am
It doesn't select wrong link because I overridden the behavior. But it tries to do it Smiley. I have to add my project to xml diagram because otherwise you can't deserialize it. I sent you an archive. File with diagram named as diagram.xml
Re: Dragging links
Reply #37 - Jan 11th, 2010 at 11:42am
This should work better:
https://mindfusion.eu/_beta/wpfdiag_linkat.zip
You'll have to do a few modifications to your project to use the new assembly:
- replace ArrowHead with ArrowHeads in the InitLinks() method.
- the DrawHandles override (NodeRoutine.cs) now takes a HandlesVisualStyle argument instead of Color
- set the reference' "Use Specific Version" property to false
Hunter
Re: Dragging links
Reply #38 - Jan 11th, 2010 at 12:07pm
Thanks. It really works much better
Hunter
Re: Dragging links
Reply #39 - Jan 28th, 2010 at 7:04am
I found an interesting effect. It looks like a bug. The effect takes place after link.Route() call. I sent you the e-mail with video which demonstrate this effect. May be it is necessary to call something after route for this case?
Re: Dragging links
Reply #40 - Jan 28th, 2010 at 11:43am
Yes, it seems we missed this case (last two points coinciding) when we changed the arrowheads type to Shape. We'll upload a fix in a few days.
Hunter
Re: Dragging links
Reply #41 - Jan 28th, 2010 at 12:46pm
Thank you
