Normal Topic Mixing Behavior.Modify and Behavior.DrawLinks (Read 5556 times)
matt.s
Jan 5th, 2010 at 5:21pm
We currently use Behavior.DrawLinks to draw links between nodes.
However, when clicking and dragging on the diagram surface we'd like to have the 'selection' behaviour that is present when Behavior.Modify is used.
Is there anyway we can achieve both of these behaviours at the same time?
Matt
Re: Mixing Behavior.Modify and Behavior.DrawLinks
Reply #1 - Jan 5th, 2010 at 6:14pm
You should get that selection behavior with DrawLinks too, unless AllowUnconnectedLinks is enabled.
If you need some more complicated unconnected links behavior, you could override DrawLinksBehavior.StartDraw() to return InteractionState(diagram.Selection, Action.Create) if there isn't any node under the mouse, otherwise return base.StartDraw(). Assign an instance of the derived behavior class to diagram.CustomBehavior.
matt.s
Reply #2 - Jan 6th, 2010 at 12:10pm
Hi Stoyan,
Overriding the behaviour worked a treat.
Thanks!
matt.s
Reply #3 - Jan 8th, 2010 at 10:16am
Hi Stoyan,
One more thing - using this method the selection does not show the square 'outline' box as the mouse is dragged.
Is there anyway to show this?
Matt
Reply #4 - Jan 8th, 2010 at 12:42pm
Hi Matt,
This shows the selection rectangle fine in my test:
return new InteractionState(Diagram.Selection, -1, Action.Create);
What does your code look like?
Are you using the latest version? - I think we had similar problems with custom behaviors before but fixed them in one of the later releases.
matt.s
Reply #5 - Jan 8th, 2010 at 12:50pm
Hi Stoyan,
Our code is the same as yours, except that we had tried 0 and 1 as the adjustment handle parameter. Have tried again with -1 to no avail.
We are using version 2.2.0. I can see there is an update to this, but the link on the email I received in Sept last year no longer works. How can I download the latest version?
Matt
Reply #6 - Jan 8th, 2010 at 1:09pm
Hi Matt,
Create an account here to download it:
http://www.clientsarea.eu/
matt.s
Reply #7 - Jan 8th, 2010 at 1:13pm
Hi Stoyan,
Sorry to be a complete pain - is there anyway I can find out what my order number was?
Matt
Reply #8 - Jan 8th, 2010 at 1:15pm
Hi Matt,
Enter your company name instead of order id.
matt.s
Reply #9 - Jan 8th, 2010 at 3:26pm
Hi Stoyan,
Using version 2.1.1 has fixed it.
Thanks!
