Normal Topic Trouble loading Diagram Link in a control node (Read 4127 times)
solisgsandc
Jan 11th, 2010 at 6:07pm
For some reason, there is a control node that is created with a UIElement of a diagramlink. I am not sure how this is created. When I save the diagram, this object is created as well. I would like to know why this is a problem in loading using LoadXML.
I delete this node and everything loads again.
<Node Class="std:ControlNode" Version="1" Id="6">
     <UIElement>
       <DiagramLink Style="Cascading" Text="" TextStyle="Center" TextBrush="#FF000000" HeadShape="None" BaseShape="None" IntermediateShape="None" HeadShapeSize="18.897637795275593" BaseShapeSize="18.897637795275593" IntermediateShapeSize="18.897637795275593" OriginAnchor="-1" DestinationAnchor="-1" SegmentCount="2" Origin="{x:Null}" Destination="{x:Null}" OriginIndex="-1" DestinationIndex="-1" Dynamic="False" RetainForm="True" AutoRoute="False" CascadeOrientation="Auto" AllowMoveStart="True" AllowMoveEnd="True" Visible="True" DrawCrossings="True" CustomDraw="None" SnapToNodeBorder="False" HandlesStyle="SquareHandles" Tag="{x:Null}" Brush="#FF78DCFF" Locked="False" Selected="False" ZIndex="0" Printable="True" ToolTip="{x:Null}" IgnoreLayout="False" Weight="1" HyperLink="" RenderTransform="1,0,0,1,87.5,27.5" Effect="{x:Null}" xmlns="clr-namespace:MindFusion.Diagramming.Wpf;assembly=MindFusion.Diagramming.
Wpf" xmlns:av="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml">
         <DiagramLink.HeadPen>
           <av:Pen Brush="#FF000000" Thickness="3" />
         </DiagramLink.HeadPen>
         <DiagramLink.Font>
           <Font Name="Arial" Size="10.75" Style="Normal" Weight="Normal" Unit="World">
             <Font.Decorations>
               <x:Null />
             </Font.Decorations>
           </Font>
         </DiagramLink.Font>
         <DiagramLink.Pen>
         </DiagramLink.Pen>
       </DiagramLink>
     </UIElement>
     <Bounds>87.5, 27.5, 125, 150</Bounds>
     <ZIndex>6</ZIndex>
     <HyperLink>
     </HyperLink>
     <Locked>False</Locked>
     <Visible>True</Visible>
     <Printable>True</Printable>
     <Brush Id="1" />
     <Pen>
       <Pen Brush="#FF000000" Thickness="1" LineJoin="Bevel" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" />
     </Pen>
     <Font>
       <Name>Arial</Name>
       <Size>10.75</Size>
       <Unit>0</Unit>
       <Bold>False</Bold>
       <Italic>False</Italic>
       <Underline>False</Underline>
       <Strikeout>False</Strikeout>
     </Font>
     <ShadowColor>#FF6E6E8C</ShadowColor>
     <ShadowOffsetX>3.77952755905512</ShadowOffsetX>
     <ShadowOffsetY>3.77952755905512</ShadowOffsetY>
     <Weight>1</Weight>
     <IgnoreLayout>False</IgnoreLayout>
     <Constraints>
       <Constraint Type="0">
         <Value>0</Value>
       </Constraint>
       <Constraint Type="1">
         <Value>0</Value>
       </Constraint>
       <Constraint Type="2">
         <Value>0</Value>
       </Constraint>
       <Constraint Type="3">
         <Value>0</Value>
       </Constraint>
       <Constraint Type="4">
         <Value>0</Value>
       </Constraint>
       <Constraint Type="5">
         <Value>False</Value>
       </Constraint>
       <Constraint Type="6">
       </Constraint>
       <Constraint Type="7">
       </Constraint>
     </Constraints>
     <Obstacle>True</Obstacle>
     <AllowIncomingLinks>True</AllowIncomingLinks>
     <AllowOutgoingLinks>True</AllowOutgoingLinks>
     <EnabledHandles>511</EnabledHandles>
     <Expanded>True</Expanded>
     <Expandable>False</Expandable>
     <HandlesStyle>4</HandlesStyle>
    </Node>
Re: Trouble loading Diagram Link in a control node
Reply #1 - Jan 11th, 2010 at 8:03pm
Are you by chance creating a DiagramNodeAdapter with a DiagramLink as its argument at some point?
solisgsandc
Reply #2 - Jan 12th, 2010 at 7:18pm
No. But I do use this statement.
diagram.CustomNodeType = typeof(DiagramLink);
Will this cause the link to be created inside a control node?
Reply #3 - Jan 12th, 2010 at 8:57pm
Yes, this automatically creates a DiagramNodeAdapter wrapper around the object instantiated from the specified type. If you need to draw links from a custom type, assign it to the CustomLinkType property.
solisgsandc
Reply #4 - Jan 13th, 2010 at 11:02pm
Thanks for confirming.
