Normal Topic Customizing diagram links (Read 4735 times)
Hunter
Jan 13th, 2010 at 1:46pm
Hello, Stoyan!
Is there any way to change direction and position of arrowhead of the link or set for example arrows at the both ends of the link?
Re: Customizing diagram links
Reply #1 - Jan 13th, 2010 at 2:17pm
You can set the HeadShape and BaseShape properties to display arrowheads at both ends. You might also handle the DrawLink event and use the DrawArrowhead method to render arrowheads anywhere you'd like.
Hunter
Reply #2 - Jan 13th, 2010 at 2:31pm
Ok. I try to do it. Thank you. But to handle DrawLink event is not a solution for me because I want to change links from the property grid when they are already drawn in the following way:
Reply #3 - Jan 13th, 2010 at 2:52pm
Do you mean you need to reverse the links' direction?
Hunter
Reply #4 - Jan 13th, 2010 at 2:55pm
Yes, reverse link direction is need too. I want to create behavior similiar to MS Visio links for example
Reply #5 - Jan 13th, 2010 at 3:13pm
You could either exchange the Origin / Destination values to really reverse the link, or exchange HeadShape / BaseShape to reverse only the arrowheads.
Hunter
Reply #6 - Jan 13th, 2010 at 3:55pm
Thank you very much!
Hunter
Reply #7 - Feb 1st, 2010 at 11:10am
When I set for link Base and Head shapes null (link without arrows) and save it to xml it don't set tags: BaseShape and HeadShape. After that I load diagram from xml and I see that saved link loaded as link with HeadShape = arrow.
Reply #8 - Feb 1st, 2010 at 12:01pm
Please try this version -
https://mindfusion.eu/_beta/wpfdiag231.zip
Hunter
Reply #9 - Feb 1st, 2010 at 1:59pm
Thanks! All is ok
