Normal Topic System.OutOfMemoryException after diagram resizing (Read 4356 times)
shalex
Jan 14th, 2010 at 6:17am
I have three diagram views on a form, a single zoomer to control zooming in these views. Sometimes I get strange black areas after placing node via drag'n'drop operation. May be these black areas was the reason of OutOfMemoryException which I've received after zooming. One of the views disappered, instead there was a white window with crossed red lines.
System.OutOfMemoryException: Недостаточн&#1
086; памяти.
в System.Drawing.Graphics.CheckErrorStatus(Int32 status)
в System.Drawing.Graphics.DrawPath(Pen pen, GraphicsPath path)
в MindFusion.Drawing.GdiGraphics.DrawPath(Pen pen, GraphicsPath path)
в MindFusion.Diagramming.ShapeNode.xc79d59e9288101bd(IGraphics x41347a961b838962, RectangleF xa6236fc5cd405c4e, Boolean x2f9dabff87b2168b, Brush xb45de92d01a0ec1f, Pen x9c79b5ad7b769b12, RenderOptions xdfde339da46db651)
в MindFusion.Diagramming.ShapeNode.DrawShadow(IGraphics graphics, RenderOptions options)
в MindFusion.Diagramming.Diagram.x826b585edd6a93e2(IGraphics x41347a961b838962, RectangleF xa6236fc5cd405c4e, Boolean x979174172ae18db3)
в MindFusion.Diagramming.Diagram.Draw(IGraphics graphics, RenderOptions options, RectangleF clipRect, Boolean noModifiedItems)
в MindFusion.Diagramming.WinForms.DiagramView.x45babdc9db40342f(IGraphics x41347a961b838962, RectangleF xd1cff1e8f8666dbe, Boolean x8de543c74cdd4f6e)
в MindFusion.Diagramming.WinForms.DiagramView.OnPaint(PaintEventArgs pe)
в System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
в System.Windows.Forms.Control.WmPaint(Message& m)
в System.Windows.Forms.Control.WndProc(Message& m)
в System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
в System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Re: System.OutOfMemoryException after diagram resi
Reply #1 - Jan 14th, 2010 at 6:43am
Could you copy the call stack here? We often get out-of-memory exceptions from GDI+ when drawing with a dashed pen while antialiasing is enabled; are you using any dashed pens?
shalex
Reply #2 - Jan 14th, 2010 at 7:08am
Yes, I use a dash pen for links. Something like:
[code]
Shape.Pen.DashStyle = DashStyle.Dash;
Shape.Pen.DashPattern = new float[] { 10, 10 };
[/code]
Reply #3 - Jan 14th, 2010 at 8:30am
We suspect the error is caused by a combination of antialiasing and graphics.PageUnit different than pixel when drawing with dashed pens. Try disabling DiagramView.SmoothingMode or set MeasureUnit to Pixel to see if it helps.
If you prefer using both antialiaing and millimeters, you might try drawing links like this:
link.CustomDraw = Full;
void diagram_DrawLink(...)
	try {
		e.Link.CustomDraw = None;
		e.Link.Draw(e.Graphics);
		e.Link.CustomDraw = Full;
	catch (Exception) {}
This is how the control draws the dashed selection rectangles, and we haven't noticed any adverse effects from catching and ignoring the exception.
shalex
Reply #4 - Jan 16th, 2010 at 2:23pm
Thank you, I'll try.
