Normal Topic Problem with resizing of ShapeNode (Read 1192 times)
shalex
Jan 16th, 2010 at 2:07pm
I use ShapeNode with a custom shape. There is a problem with resizing of shape when I try to catch a handle if a mouse cursor position is out of the shape and nothing happens. I tried all of HandleStyle values and the problem is for any. If a mouse cursor is on the shape (its visible part), everething is ok. Could you answer is it my problem and I do something wrong or you can check are there any conditions which could lead to such behavior.
Thanks.
Re: Problem with resizing of ShapeNode
Reply #1 - Jan 17th, 2010 at 11:44am
Are you using the latest version of the control (V5.3.3)? I have tried this in the Demo / Miscellaneous features / Complex Shapes page, but it worked fine. It seems to work ok with both DiagramView.ModificationStart modes. If this works for you too in the demo, could you post here or email to support@mindfusion.eu the diagram and diagramview initialization code from your project?
