Normal Topic Custom nodes as on Tutorial 3 (Read 1685 times)
baba
Jan 20th, 2010 at 3:09pm
I'm using the trial version as my company decided to use your library to provide diagram-design functionalities in our software products.
What I am trying to do: basically I'd need something very similar to what you do in Tutorial3 but I'm in troubles with UI as, even in Tutorial3, nodes are created as ShapeNode type when the user drags the mouse over an empty region, right?
I instead need the node to be created as, following the Tutorial3 scenario, as an OrgChartNode.
What should I do to reach this result?
Is there an alternative way to adorn the ShapeNode as I need? I've tried to apply the generic.xaml template to the type ShapeNode but nothing changes... I'm now trying the code-behind way.... but I am running out of ideas.... Can you help please?
Cheers,
baba.
Re: Custom nodes as on Tutorial 3
Reply #1 - Jan 20th, 2010 at 3:22pm
Assign an instance of this class to diagram.CustomBehavior:
public class OrgChartBehavior : LinkNodesBehavior
	public OrgChartBehavior(Diagram diagram) : base(diagram) {}
	protected override DiagramNode CreateNode()
		return new OrgChartNode();
baba
Reply #2 - Jan 20th, 2010 at 3:44pm
Stoyo wrote on Jan 20th, 2010 at 3:22pm:
<snip>
It helped A LOT, thanks! Smiley
Cheers,
baba.
