Normal Topic Getting this error after adding custom 404 file (Read 2280 times)
sushiil
Jan 25th, 2010 at 9:19pm
This is the exception occurs only when we add custom 404 error. Please suggest how can we fix this problem.
Exception in thread "thread applet-com/mindfusion/diagramming/DiagramApplet.class-1" java.lang.NoClassDefFoundError: IllegalName: MY FOLDER/meta-inf/services/javax.xml.parsers.documentbuilderfactory
Re: Getting this error after adding custom 404 fil
Reply #1 - Jan 26th, 2010 at 8:54am
We know of this happening if the .jar file is inside a forms-authentication protected section of the site. Have you by chance enabled authentication together with the custom error?
sushiil
Reply #2 - Jan 26th, 2010 at 1:40pm
Thanks for the reply, We only have windows authentication and haven't enabled forms authentication. We only added custom 404 error. When we remove IIS custom error 404 to use Default then it works fine but if we add a URL to a 404 custom errors then we have this problem.
Reply #3 - Jan 26th, 2010 at 6:53pm
I could not reproduce this. What JRE and IIS versions are you using? In any case, you might try placing the .jar file inside some location on your server that uses the default 404 response and set the JarLocation property to the new URL for the jar.
