Normal Topic some MonthSettings weirdness (Read 5476 times)
springy
Jan 29th, 2010 at 9:56am
<UserControl xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:schedule="http://mindfusion.eu/scheduling/wpf"
xmlns:schedCode="clr-namespace:MindFusion.Scheduling;assembly=MindFusion.Scheduling.Wpf">
<schedule:Calendar Name="calendar" CurrentView="MonthRange" Theme="Vista"  Date="2010-01-01">
<schedule:Calendar.MonthRangeSettings>
<schedule:MonthRangeSettings NumberOfMonths="4" MonthsPerRow="2" VisibleRows="2" />
</schedule:Calendar.MonthRangeSettings>
<schedule:Calendar.MonthSettings>
<schedule:MonthSettings WeekHeaderStyle="Left">
<schedule:MonthSettings.DaySettings>
<schedule:CellSettings HeaderSize="12">
<schedule:CellSettings.HeaderStyle>
<schedule:CalendarStyle FontSize="8" Foreground="Lime" />
</schedule:CellSettings.HeaderStyle>
</schedule:CellSettings>
</schedule:MonthSettings.DaySettings>
</schedule:MonthSettings>
</schedule:Calendar.MonthSettings>
<schedule:Calendar.Schedule>
<schedCode:Schedule>
<schedCode:Schedule.Items>
<schedCode:Appointment StartTime="2010-02-01" AllDayEvent="True" HeaderText="Test" />
</schedCode:Schedule.Items>
</schedCode:Schedule>
</schedule:Calendar.Schedule>
</schedule:Calendar>
</UserControl>
  • Is there a style setting for the overflow days (2009-12-27 - 2009-12-31 and 2010-04-1 - 2010-04-08)?
  • add 'Height="600"' to the Calendar node: The appointment becomes visible -- no problem here.
  • change 'Height="600"' to 'Width="600"': The day-of-week header is far too big (height) now -- the WeekHeader is totally misaligned
  • add 'HeaderPosition="Left"' to MonthSettings.DaySettings: Still no appointment is being shown -- you'll have to add Height>400 to the Calendar node (but at least then the day-of-week header and WeekHeader work well again).
  • remove the Width and Height from the Calendar node and add 'TrailingWeekCount="3" LeadingWeekCount="3"' to MonthSettings: Only the first and the last month have the correct amount of trailing/leading weeks, Feb and Mar have corrupt day-of-week headers again and the WeekHeader is misaligned everywhere (even when you remove 'FontSize="8"' from MonthSettings.HeaderStyle).
/\/\arkus.
Re: some MonthSettings weirdness
Reply #1 - Jan 29th, 2010 at 11:48am
Another version of the control can be downloaded from the link below:
[url]https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.Wpf.2.1b.zip[/url]
The Calendar control no longer attempt to calculate a desirable size for its content. It now uses all of the available space unless its Width and Height properties have been set explicitly. Therefore, placing the control in a grid cell will cause the control to span the entire cell. Let me know if this behavior works well for you.
[quote]Is there a style setting for the overflow days (2009-12-27 - 2009-12-31 and 2010-04-1 - 2010-04-08)? [/quote]
The style of the so-called padding dates can be customized through the MonthSettings.PaddingDaysStyle property.
[quote]Only the first and the last month have the correct amount of trailing/leading weeks...[/quote]
This is by design. In MonthRange view only the first and the last months display padding days.
springy
Reply #2 - Jan 29th, 2010 at 12:00pm
Now I get in designer:
System.InvalidOperationException
Layout measurement override of element 'MindFusion.Scheduling.Wpf.Calendar' should not return PositiveInfinity as its DesiredSize, even if Infinity is passed in as available size.
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at MS.Internal.Designer.ZoomableViewPresenter.DesignerBackground.MeasureOverride(Size constraint)
   at System.Windows.Controls.Decorator.MeasureOverride(Size constraint)
   at Microsoft.Windows.Design.Interaction.DesignerView.MeasureOverride(Size constraint)
   at MS.Internal.Designer.Viewport.MeasureOverride(Size availableSize)
   at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
   at System.Windows.Interop.HwndSource.SetLayoutSize()
   at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
   at System.Windows.Interop.HwndSource.set_RootVisual(Visual value)
   at MS.Internal.Designer.VSIsolatedDesigner.ViewHolder.Initialize()
   at MS.Internal.Designer.VSIsolatedDesigner.ViewHolder..ctor(UIElement content)
   at MS.Internal.Designer.VSIsolatedDesigner.VSIsolatedView.get_ViewHandle()
   at MS.Internal.Host.Isolation.IsolatedView.get_ViewHandle()
   at MS.Internal.Designer.DesignerPane.LoadDesignerView()
Reminds me of the time when I did a custom panel implementation some time ago.
/\/\arkus.
Reply #3 - Feb 1st, 2010 at 8:57am
springy
Reply #4 - Feb 1st, 2010 at 9:29am
Hmm.. Now the size is 0?
BTW:
Then the grid cell will give the control explicit width and height.
But if you look at the initial sample: Neither the usercontrol nor the calendar control has width or height set.
I know it's not simple especially with MonthsPerRow>1 -- but an automatic height which at least shows items (if there are any) but doesn't take too much space would be very cool.
/\/\arkus.
Reply #5 - Feb 1st, 2010 at 10:56am
We will try to implement automatic measurement in the future. But as of yet, the control size should be set explicitly.
