Normal Topic DiagramApplet.class not found (Read 5061 times)
manasr
Feb 2nd, 2010 at 7:09pm
hi
i am using Net Diagram.It is working fine in my local system.On the server,I installed my application and while running,it gives an error as -- class com/mindfusion/diagramming/DiagramApplet.class not found.Exception: java.lang.ClassNotFoundException: com.mindfusion.diagramming.DiagramApplet.class.
I have installed the latest JRE as well.I have added Jdiagram.jar file to my website folder also.But cannot figure out as to why this is happening.
Re: DiagramApplet.class not found
Reply #1 - Feb 2nd, 2010 at 7:34pm
If you paste the applet's URL into the browser's address bar, does it offer you to download the .jar file?
manasr
Reply #2 - Feb 2nd, 2010 at 7:39pm
i am a new bee in this....from where can i get the applet's url?
Reply #3 - Feb 2nd, 2010 at 7:43pm
Replace the name of the aspx file you see in the address bar with JDiagram.jar, e.g. make it something like www.mysite.com/MyApp/JDiagram.jar, and see if the browser can successfully download this file.
manasr
Reply #4 - Feb 2nd, 2010 at 7:49pm
thanks for this...my aspx page is http://localhost/hrms/orgstructure/abc.aspx so i should make it http://localhost/hrms/orgstructure/jdiagram.jar or should it be http://localhost/hrms/jdiagram.jar where hrms is my website folder which actally contains jar file......i dont have access to server at the moment.....what should i do if the browser does not offers me to download the jar file...
Reply #5 - Feb 2nd, 2010 at 7:58pm
If the .jar file is in a different location than the .aspx file, you should set the JarLocation property to the applet's full URL. Try setting it to http://localhost/hrms/jdiagram.jar, or whatever URL works for you when you try to download from the browser address bar.
manasr
Reply #6 - Feb 2nd, 2010 at 8:03pm
Thanks Stoyan.....i 'll check it and get back to you in a couple of minutes....in case if i am unable to download the jar file using applet url,then what should i do?
Reply #7 - Feb 2nd, 2010 at 8:11pm
In such case, enable IIS logging and check what HTTP response is logged for the "GET JDiagram.jar" request.
