Normal Topic Behavior.DrawLinks (Read 1900 times)
Vladimir
Behavior.DrawLinks
Feb 3rd, 2010 at 9:30am
Hello!
By default mouse left button drawing nodes with default shapes.
Quite long time I was trying to find how to bind selection to it.
I was wondered that behavior that I need is named "DrawLinks". It's not drawing links. It's selecting diagram items.
May be I misunderstood something?
Thank you for your attention.
Re: Behavior.DrawLinks
Reply #1 - Feb 3rd, 2010 at 11:45am
DrawLinks will draw links between existing nodes, or unconnected ones too if AllowUnconnectedLinks is enabled. Otherwise it selects items. If you want to disable drawing links, set Behavior=Modify.
Vladimir
Reply #2 - Feb 3rd, 2010 at 12:13pm
Thank you very much!
I think that names of some values are confusing developers.
"Modify" is not very clear and transparent. It'll be better to name it "SelectAndModify" for example.
Best wishes,
  Vladimir.
