Normal Topic Using Flowchart.Net from a windows service (Read 1145 times)
Sam
Feb 8th, 2010 at 6:00pm
Is it possible (and supported) to use FlowChart.Net from a windows service to create a diagram and then save it out to a bitmap?
Sam
Re: Using Flowchart.Net from a windows service
Reply #1 - Feb 8th, 2010 at 6:12pm
Yes, you can load the mindfusion.diagramming.dll assembly into a service process, generate a Diagram and call its CreateImage method to get a bitmap.
