Normal Topic Z order of Links (Read 2352 times)
bkernan
Z order of Links
Feb 12th, 2010 at 10:04pm
I have a large JavaApplet mode diagram where laid out in the Layered Layout. I would like all my nodes to be above all the links. Currently it depends on which node/link was rendered/created first I beleive.
I have tried looping through the Diagram.Items and if its a link I call the ZBottom() method, which doesn't change anything. I also loop through the Diagram.Links and do the same thing.
I cannot call ZBottom/ZTop while rendering nodes because I create them  interchangeably.
Please let me know if what I am requesting is even possible. : ) Thanks!
Re: Z order of Links
Reply #1 - Feb 14th, 2010 at 11:04am
The ZIndex setter modifies the diagram.Items collection, and changing the Z order while looping over Items might not work as expected, or could even throw an exception if using an enumerator / foreach loop.
It should be safe to change the Z order from a loop over diagram.Nodes or diagram.Links. In addition, by default selected items and their links appear over non-selected ones, so if you want to show some items selected, disable SelectionOnTop:
diagram.SelectionOnTop = false;
foreach (DiagramLink link in diagram.Links)
	link.ZBottom();
bkernan
Reply #2 - Mar 24th, 2010 at 3:11pm
I tried that out after I arranged the nodes with layered layout and it did not work. I assume because the links are attached to the nodes, the links retain the same z index as their node that they start from.
Let me know if this is changed in an new version : )
Reply #3 - Mar 24th, 2010 at 3:42pm
Could you email us a sample page that reproduces this?
