Normal Topic component uses Microsoft.Windows.Design 3.5 (Read 5744 times)
springy
Feb 22nd, 2010 at 9:40am
which is a Visual-Studio 2008 only DLL.
I have an app which fails on close on all machines which have no VS2008 installed. The problem gets triggered by an serializer which seems to check some code points which don't get invoked in normal situations:
System.IO.FileNotFoundException was unhandled by user code
  Message=Die Datei oder Assembly "Microsoft.Windows.Design, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
  Source=mscorlib
  FileName=Microsoft.Windows.Design, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
  FusionLog==== Zustandsinformationen vor Bindung ===
LOG: Benutzer = usn-Mobil\user
LOG: DisplayName = Microsoft.Windows.Design, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
 (Fully-specified)
LOG: Appbase = file:///C:/Users/user/Desktop/MyApp/MyCompany.MyApp.Cockpit/bin/Debug/
LOG: Ursprünglicher PrivatePath = NULL
Aufruf von Assembly : MindFusion.Scheduling.Wpf, Version=2.1.0.0, Culture=neutral, PublicKeyToken=d12631580350466b.
LOG: Diese Bindung startet im default-Load-Kontext.
LOG: Die Anwendungskonfigurationsdatei wird verwendet: C:\Users\user\Desktop\MyApp\MyCompany.MyApp.Cockpit\bin\Debug\MyApp-Cockpit.vshost.exe.config
LOG: Die Computerkonfigurationsdatei von C:\Windows\Microsoft.NET\Framework\v2.0.50727\config\machine.config wird verwendet.
LOG: Verweis nach der Richtlinie: Microsoft.Windows.Design, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
LOG: Download von neuem URL file:///C:/Users/user/Desktop/MyApp/MyCompany.MyApp.Cockpit/bin/Debug/Microsoft.Windows.Design.DLL.
LOG: Download von neuem URL file:///C:/Users/user/Desktop/MyApp/MyCompany.MyApp.Cockpit/bin/Debug/Microsoft.Windows.Design/Microsoft.Windows.Design.DLL.
LOG: Download von neuem URL file:///C:/Users/user/Desktop/MyApp/MyCompany.MyApp.Cockpit/bin/Debug/Microsoft.Windows.Design.EXE.
LOG: Download von neuem URL file:///C:/Users/user/Desktop/MyApp/MyCompany.MyApp.Cockpit/bin/Debug/Microsoft.Windows.Design/Microsoft.Windows.Design.EXE.
But nevertheless a end user assembly should not reference any design-time-only assemblies at all.
[Stacktrace in next msg]
/\/\arkus.
springy
Re: component uses Microsoft.Windows.Design 3.5
Reply #1 - Feb 22nd, 2010 at 9:41am
  StackTrace:
	 bei System.ModuleHandle.ResolveType(Int32 typeToken, RuntimeTypeHandle* typeInstArgs, Int32 typeInstCount, RuntimeTypeHandle* methodInstArgs, Int32 methodInstCount)
	 bei System.ModuleHandle.ResolveTypeHandle(Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
	 bei System.Reflection.Module.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments)
	 bei System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, Module decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, RuntimeMethodHandle& ctor, Boolean& ctorHasParameters, Boolean& isVarArg)
	 bei System.Reflection.CustomAttribute.GetCustomAttributes(Module decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes)
	 bei System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeType type, RuntimeType caType, Boolean inherit)
	 bei System.RuntimeType.GetCustomAttributes(Type attributeType, Boolean inherit)
	 bei System.ComponentModel.TypeDescriptor.CheckDefaultProvider(Type type)
	 bei System.ComponentModel.TypeDescriptor.NodeFor(Type type, Boolean createDelegator)
	 bei System.ComponentModel.TypeDescriptor.GetReflectionType(Type type)
	 bei MS.Internal.ComponentModel.DependencyObjectPropertyDescriptor.GetAttachedPropertyMethod(DependencyProperty dp)
	 bei MS.Internal.ComponentModel.DependencyPropertyKind.get_IsAttached()
	 bei MS.Internal.ComponentModel.APCustomTypeDescriptor.GetProperties(Attribute[] attributes)
	 bei MS.Internal.ComponentModel.APCustomTypeDescriptor.GetProperties()
	 bei System.ComponentModel.TypeDescriptor.TypeDescriptionNode.DefaultExtendedTypeDescriptor.System.ComponentModel.ICustomTypeDescriptor.GetProperties()
	 bei System.ComponentModel.TypeDescriptor.GetPropertiesImpl(Object component, Attribute[] attributes, Boolean noCustomTypeDesc, Boolean noAttributes)
	 bei System.ComponentModel.TypeDescriptor.GetProperties(Object component)
	 bei System.Windows.Markup.Primitives.ElementMarkupObject.<GetProperties>d__0.MoveNext()
	 bei System.Windows.Markup.Primitives.MarkupWriter.RecordNamespaces(Scope scope, MarkupObject item, IValueSerializerContext context, Boolean lastWasString)
	 bei System.Windows.Markup.Primitives.MarkupWriter.WriteItem(MarkupObject item)
	 bei System.Windows.Markup.Primitives.MarkupWriter.SaveAsXml(XmlWriter writer, MarkupObject item)
	 bei System.Windows.Markup.Primitives.MarkupWriter.SaveAsXml(XmlWriter writer, Object instance)
	 bei System.Windows.Markup.XamlWriter.Save(Object obj, XmlWriter xmlWriter)
	 bei ActiproSoftware.Windows.Serialization.XamlSerializer.SaveToXmlWriter(XmlWriter writer, Object value)
	 bei ActiproSoftware.Windows.Serialization.XamlSerializer.SaveToString(Object value)
	 bei ActiproSoftware.Windows.Controls.Ribbon.Customization.RibbonControlPathList.a()
	 bei ActiproSoftware.Windows.Controls.Ribbon.Ribbon.SerializeQuickAccessToolBarItems()
	 bei MyCompany.MyApp.Cockpit.MainWindow.OnClosing(CancelEventArgs e) in C:\Users\user\Desktop\MyApp\MyCompany.MyApp.Cockpit\MainWindow.xaml.cs:Zeile 94.
	 bei System.Windows.Window.WmClose()
/\/\arkus.
Reply #2 - Feb 22nd, 2010 at 10:32am
This is something we overlooked. I will look into it and get back to you.
Reply #3 - Feb 22nd, 2010 at 12:50pm
An updated version of the control can be downloaded from the following link:
https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.Wpf.2.1g.zip
The control no longer references any design-time assemblies.
Thanks again for your feedback.
springy
Reply #4 - Feb 22nd, 2010 at 4:22pm
Thanks again for solving problems that fast  Cheesy
/\/\arkus.
kennyui
Reply #5 - Feb 26th, 2010 at 7:01pm
Also - just hit the same problem and decided to check the forum before panicking. Great support. Thank you!
AIM
