Normal Topic Node.FontStyle & Cell.FontStyle Issue (Read 1683 times)
steve
Feb 25th, 2010 at 1:11pm
Hi - I've been using the DiagramLite trial version dll in my dev project, and have just purchased the full version of DiagramLite 1.3 - and replaced the dll in the project.
Everything still compiles and runs fine (as far as I have tested so far) except that the FontStyle and FontWeight properties on ShapeNode and TableCell objects dont seem to be working (although they were working correctly with the demo dll).
Has anyone else experienced this? Any suggestions?
Steve
Re: Node.FontStyle & Cell.FontStyle Issue
Reply #1 - Feb 25th, 2010 at 3:59pm
What version number were you using before? It seems these properties are inherited from the base Control class and I can't see them used anywhere in the component's code. In case you were using V1.1 until now - since the 1.2 release ShapeNodes and TableNodes are defined through control templates that host TextBlock elements, and maybe the inherited values are not used since then.
We'll release V1.4 soon and will add template bindings for these properties. For the time being you could copy the default templates from the help file and modify them to include FontStyle and Weight.
steve
Reply #2 - Feb 25th, 2010 at 4:01pm
Thanks Stoyan - I'll try that.
Reply #3 - Mar 3rd, 2010 at 4:16pm
Hi Steve,
The node templates in this version bind to all font-related properties derived from Control:
https://mindfusion.eu/_beta/diaglite14_sp.zip
