Normal Topic How to use applet on jsp/html page (Read 2303 times)
hump.O
Feb 26th, 2010 at 8:23am
I'm starting to learn JDiagram 3 and have problems with run jdiagram as applet. I deploy JSPSample.war on my tomcat but applet doesn't appear. It is the same problem when i try to run applet demo from jdiagram samples. What i'm doing wrong or what i forgot. It's very important for my to run jdiagram as applet.
Sorry for my english Smiley
Re: How to use applet on jsp/html page
Reply #1 - Feb 26th, 2010 at 8:48am
Have you copied the jdiagram.jar file to the sample's folder?
hump.O
Reply #2 - Feb 26th, 2010 at 8:56am
You mean to 'Applet demo' folder? Yes, I run start.htm but nothing has changed Sad
hump.O
Reply #3 - Feb 26th, 2010 at 9:02am
It was a problem with internet browser. It works on internet explorer but doesnt work on Firefox Sad .. what is the difference?
Reply #4 - Feb 26th, 2010 at 10:21am
Probably you don't have the Java plugin installed for Firefox. Check if the Java Control Panel / Advanced tab has the "Default Java for Browsers" option enabled for Firefox.
