Normal Topic SVG in Node (Read 1844 times)
granit
SVG in Node
Mar 2nd, 2010 at 5:04pm
Hello!
I use your trial version of WpfDiagramming library. It's really nice product! Wink
Is there any possibility to render (draw) svg (or may be wmf) image into ShapeNode (or maybe into another your Node class)?
It's very important for me, because I'd like to have scaling image into nodes of diagramm.
Example of svg-file you can find here:
http://rapidshare.com/files/357933006/test1.svg.html
Thanks in advance!
Re: SVG in Node
Reply #1 - Mar 2nd, 2010 at 5:53pm
We have SVG support only in the WinForms version at this time. If you need scalable graphics in WPF, you could assign a XAML drawing to the Image property of ShapeNodes. I think you can convert from WMF/SVG to XAML using MS Expression Design.
granit
Re: SVG in Node
Reply #2 - Mar 3rd, 2010 at 9:52am
Thank you for your answer. Smiley
I will try to do this.
