Normal Topic Cancel interaction with ESC and start another one (Read 1366 times)
Cornel
Mar 9th, 2010 at 8:09am
I need to cancel the interaction using ESC key and for this I used diagram.Interaction.CancelNow().
It worked, but when I start another interaction it starts from the point the cancelled interaction started instead of current mouse position.
What to do (version 5.3.3)?
Cornel
Re: Cancel interaction with ESC and start another
Reply #1 - Mar 9th, 2010 at 10:13am
For now you could cancel it as shown below:
private void diagramView_KeyDown(object sender, KeyEventArgs e)
	if (e.KeyCode == Keys.Escape && diagram.Interaction != null)
		diagram.Interaction.Cancel(diagram);
		diagram.Interaction = new InteractionState(null, 0, Action.None);
		diagramView.Invalidate();
The Interaction Cancel/CancelNow methods are mostly for internal use by the View classes and validation events. We'll implement some official method for canceling the interaction in the next release.
Cornel
Reply #2 - Mar 9th, 2010 at 10:41am
It worked ok.
Cornel
