Normal Topic TimelineView and appointment spanning two days (Read 2697 times)
smartgui
Mar 9th, 2010 at 11:24am
sorry, I have a problem with the calendarview.TimelineView.
If I have an appointment spanning over two days it is in most cases not possible to move the appointment with the mouse!
It isn't possible to extend the EndTime in most cases, too. But you can adjust the EndTime in direction of the StartTime.
In example, if you have a StartTime of 22:30 (10:30pm) and a EndTime of 01:00am at the next day, you can't move the appointment with the mouse.
If you have an appointment with StartTime and EndTime at the SAME day all is working fine.
Any ideas?
Using WpfSchedule V2.1 (wpfschedule.dll V5.5.0.4) , Windows XP Prof. 32 Bit.
Wolfram
Re: TimelineView and appointment spanning two days
Reply #1 - Mar 9th, 2010 at 11:38am
Are you referring to the Timetable view? I made some tests trying to reproduce the described scenario but everything seems to be working fine - I can move items spanning two days with the mouse. If you are able to send me a sample illustrating what you are experiencing to support@mindfusion.eu this will be a big help.
Reply #2 - Mar 9th, 2010 at 12:51pm
I took a look at the screenshots you sent me. Are you positive you are using the scheduling components of MindFusion?
« Last Edit: Mar 9th, 2010 at 3:05pm by Meppy »
