Normal Topic LaneGrid setup, 2 rows 1 column and re-sizable (Read 1973 times)
breiny
Mar 10th, 2010 at 10:33pm
I am new to the WpfDiagram, I would like to setup the LaneGrid to have 1 column with 2 rows, that auto-sizes to the window size. I have looked at the provided Lanes sample solution, but I can't figure out how to set the row height, or column width. Any help would be appreciated
Re: LaneGrid setup, 2 rows 1 column and re-sizable
Reply #1 - Mar 11th, 2010 at 8:59am
Assuming that diagramView is a variable referencing the DiagramView object of interest, here is the C# code to setup the grid:
Diagram diagram = diagramView.Diagram;
MindFusion.Diagramming.Wpf.Lanes.Grid laneGrid = diagram.LaneGrid;
laneGrid.ColumnCount = 1;
laneGrid.RowCount = 2;
diagram.EnableLanes = true;
The code above simply initializes the lane grid with two rows and a column. In order to resize the rows and the column, we attach a handler to the DiagramView's SizeChanged event. Then assign the appropriate width and height to the grid columns and rows respectively. Here is the implementation of the SizeChanged event hander:
void diagramView_SizeChanged(object sender, SizeChangedEventArgs e)
      double columnWidth = diagramView.ActualWidth - laneGrid.GetRowHeaderBounds().Width - SystemParameters.VerticalScrollBarWidth;
      double rowHeight = (diagramView.ActualHeight - laneGrid.GetColumnHeaderBounds().Height - SystemParameters.HorizontalScrollBarHeight) / laneGrid.RowHeaders.Count;
      laneGrid.ColumnHeaders[0].Width = columnWidth;
      laneGrid.RowHeaders[0].Height = rowHeight;
      laneGrid.RowHeaders[1].Height = rowHeight;
The code above calculates the width of the column by subtracting the width of the row headers and the width of the vertical scroll bar from the actual width of the diagram view. A similar calculation is performed for row heights.
I hope this helps.
breiny
Reply #2 - Mar 11th, 2010 at 2:46pm
Thanks a bunch, that worked great. This is the code that I needed.
[code]
[/code]
