Normal Topic recurrence exception (Read 5369 times)
Amyuni
Mar 11th, 2010 at 2:59pm
I got a little confused when using the MarkException. Does MarkException create a new item added into the schedule.Items collection? If so, Does this new item has a recurrence? What is the recurrence's Master? How to exclude this item when load all items into the schedule in ItemFinder.GetAllItems?
Amyuni
Re: recurrence exception
Reply #1 - Mar 11th, 2010 at 3:34pm
No, MarkException does not create new items. Instead it registers the occurrence specified as argument as an exception within its recurrence pattern. This method is also meant to programmatically delete individual occurrences from a recurrence.
If you want to "hide" (delete) specific occurrences from a recurrence pattern, you have to generate those occurrences first, by calling GenerateItems on the Recurrence object. Then, you have to invoke MarkException, passing as argument a reference to the item you wish to hide (delete). The following example demonstrates how to hide (delete) all occurrences located within a specified date interval:
ItemCollection items =
      recurrence.GenerateItems(new DateTime(2010, 3, 1), new DateTime(2010, 3, 31));
foreach (Item item in items)
      recurrence.MarkException(item, true);
Let me know if this helps.
Amyuni
Reply #2 - Mar 11th, 2010 at 6:15pm
Thank you. My problem is how to save the updated information of exception instance. I figured it out.
