Normal Topic Editing Caption in ContainerNode (Read 2121 times)
Amx
digito ergo sum
Mar 12th, 2010 at 10:11am
I need to have editables ShapeNodes and editable ContainerNodes.
For ShapeNodes, when I create it, call Diagram.BeginEdit(node) and I can edit Text.
ContainerNode have Caption field, instead of Text. I try calling Diagram.BeginEdit(node) but only result is the Caption that shift at center of ContainerNode (to return left-aligned when I click in a point of Diagram area outside node), but I can't edit.
How can I allow user change Caption text on ContainerNode?
Amx
Re: Editing Caption in ContainerNode
Reply #1 - Mar 12th, 2010 at 11:15am
It worked fine in my test project. Are you by chance handling the NodeTextEditing event?
Amx
digito ergo sum
Reply #2 - Mar 12th, 2010 at 11:59am
I'm sorry, my mistake (I forced focus on diagram to handle a keypress event in every condition).
Now I can edit it, but I have another problem:
I AddNode by code, inserting a Caption string ("caption1" in example).
User may confirm or change text (inserting "caption2" in example)
I handle NodeTextEdited and when edit is done I check Caption and i find (correctly) "caption2". But on screen, the old uncorrect "caption1" string still remains until I do something (move node, collapse, etc.). Seems to be a refresh problem.
These handling I have described is the same for Text field of ShapeNodes but with ShapeNodes it's all ok.
Amx
Reply #3 - Mar 13th, 2010 at 11:44am
This also works fine for me, but try calling the Repaint method of the node if it's not refreshed correctly when the event handler runs.
