Normal Topic Routing links orthogonally (Read 4100 times)
Cornel
Mar 12th, 2010 at 11:08am
We need to route links (polyline) orthogonaly.
The QuickRouter seems to do the job, but when a link like "]" is drawn the horizontal segments are too big and the vertical segment is too far from nodes.
The GridRouter doesn't draw the links orthogonally.
How to solve this?
Cornel
Re: Routing links orthogonally
Reply #1 - Mar 12th, 2010 at 11:33am
You could set the links' Style to Cascading if you need them routed orthogonally.
Cornel
Reply #2 - Mar 16th, 2010 at 8:40am
Hi Stoyan,
We cannot set the style to Cascading because we need polylines. Only the route proposed should be orthogonal when users ask for that.
We tried to set the style to Cascading before route and then to set it back to Polyline but the results were not what we expected. The QuickRouter routes polylines orthogonally, the only problem is that a lot of space is taken, like in the picture bellow:
The link between B-T02 and B-A02 is routed too far from the nodes; also the link between B-A02 and B-T03.
How to fix this?
Cornel
Reply #3 - Mar 16th, 2010 at 11:15am
You could clone the cascading links' ControlPoints after routing them with GridRouter, and assign them back to the link after changing Style to Polyline. Or otherwise you might add some temporary obstacle nodes around the pizzeria thing to make sure the links do not cross the boundary there.
QuickRouter has some code that shortens U-bends to be no longer than 3cm, and it seems you are getting about that limit. We'll expose this as a property so you could set it to a smaller value.
Cornel
Reply #4 - Mar 17th, 2010 at 8:03am
Hi Stoyan,
I already did that, but the problem is that when I change the style the origin and destination points change.
This morning I read the post http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=126874717... and after that I did the following: first I keep the original origin and destination points; then I change the style, set back origin and destination, clone the control points, set back the style and then set the control points:
            PointF oldOrigin = this.ControlPoints[0];
            PointF oldDestination = this.ControlPoints[this.ControlPoints.Count - 1];
            LinkStyle oldStyle = this.Style;
            this.Style = LinkStyle.Cascading;
            this.ControlPoints[0] = oldOrigin;
            this.ControlPoints[this.ControlPoints.Count - 1] = oldDestination;
            this.UpdateFromPoints(false, false);
            bool retval = base.Route();
            PointCollection points = this.ControlPoints.Clone();
            this.Style = oldStyle;
            this.ControlPoints.Clear();
            this.ControlPoints.AddRange(points);
            this.UpdateFromPoints(true, true);
It works now. Thank you!
About the QuickRouter:
When that property will be available? In the next release?
Cornel
Reply #5 - Mar 17th, 2010 at 12:11pm
We'll try to add it in the next few days. Could you email this to support@mindfusion.eu for our testing, saved as xml?
Cornel
Reply #6 - Mar 17th, 2010 at 1:46pm
I can't send it because it is just a picture.
I created something similar using the Demo program; I'll send that xml to support.
Cornel
Reply #7 - Mar 23rd, 2010 at 1:10pm
This version adds QuickRouter.UBendMaxLen property:
https://mindfusion.eu/_beta/fcnet_534_route.zip
The default is 30; setting it to 10 or 15 seems to work fine for the sample you sent us.
Cornel
Reply #8 - Mar 24th, 2010 at 6:45am
Thanks.
Cornel
