Normal Topic ZOrder for attached node (Read 1111 times)
shalex
Mar 13th, 2010 at 1:27pm
I have following code:
[code]            satelliteNode.Constraints.KeepRatio = true;
           satelliteNode.HandlesStyle = HandlesStyle.Invisible;
           satelliteNode.EnabledHandles = AdjustmentHandles.None;
           satelliteNode.AttachTo(mainNode, AttachToNode.TopLeft);
           satelliteNode.Locked = true;
           mainNode.ZLevelUp();
           mainNode.SubordinateGroup.AutoDeleteItems = true;
[/code]
The attached node should be always behind the main node, but if I select the main node, the attached appears as top most. How to avoid that?
Re: ZOrder for attached node
Reply #1 - Mar 14th, 2010 at 10:24am
Set diagram.SortGroupsByZ = true;
