Normal Topic Error when starting class the second time (Read 2200 times)
elwin68
Mar 15th, 2010 at 3:05pm
I have created a test application with the calendar. When running it everything works well.
After changing the application type from 'Windows Form Application' to 'Class Library' it goes wrong.
When calling the calendar from our ERP software the first time it goes well. When closing the calendar and starting it the second time the following error occures:
An entry with the same key already exists.
I noticed when I don't create appointments everything goes well. So I think the problem is the appointments are saved when closing the calendar. When starting it again the appointments are created again.
I use the clear command at the beginning to clear everything. This doesn't help.
Can you give me a clue to close everything in the good way so I don't get the error the second time?
Thanks in advance.
Re: Error when starting class the second time
Reply #1 - Mar 15th, 2010 at 3:21pm
Is there any possibility to supply me with a stack trace of the exception?
elwin68
Reply #2 - Mar 19th, 2010 at 2:15pm
Hello Meppy,
May be it's difficult or maybe there no time.
Only to be sure, did you get me email with the detail information of the error?
